[FAQ Nissan] Calcul map turbo
Auteur Message
civic_16Turbal Hors ligne
30-06-2006, 13:17:59   -   [FAQ Nissan] Calcul map turbo
Déjà une map de compresseur ne peut s'exprimer qu'avec rapport de pression et débit, on ne parle que de compresseur pas de turbine.
Une explication : (en anglais (cours), j'ai repris en Français le plus intéressant)
Compressor Selection
When using the formula's below, you will need to use compressor flow maps and work with the formulas until you size the compressor that will work for your application. Compressor flow maps are available from the manufacturer, or do a search on the web, you'll find that they are readily available. On the flow maps, the airflow requirements should fall somewhere between the surge line and the 60% efficiency line, the goal should be to get in the peak efficiency range at the point of your power peak. In this article I will walk through an example as I explain it, once you understand it, you can get the the formula's in the Sizing Formula's tech article for quicker reference.
Engine Airflow Requirements /
(Le souci c'est qu'on parle en unités US )
In order to select a turbocharger, you must know how much air it must flow to reach your goal. You first need to figure the cubic feet per minute of air flowing through the engine at maximum rpm. The the formula to to this for a 4 stroke engine is:
(CID × RPM) ÷3456 = CFM
For a 2 stroke you divide by 1728 rather than 3456. Lets assume that you are turbocharging a 350 cubic inch engine That will redline at 6000 rpm.
(350 × 6000) ÷ 3456 = 607.6 CFM
Autre souci : le rendement n'est pas parfait (en gros) :
The engine will flow 607.6 CFM of air assuming a 100% volumetric efficiency. Most street engines will have an 80-90% VE, so the CFM will need to be adjusted. Lets assume our 350 has an 85% VE.
607.6 × 0.85 = 516.5 CFM
Our 350 will actually flow 516.5 CFM with an 85% VE.
Presure Ratio
ça c'est important, puisque ensuite on s'en sert pour se repérer sur les map compresseur.
The pressure ratio is simply the pressure in compared to the pressure out of the turbocharger. The pressure in is usually atmospheric pressure, but may be slightly lower if the intake system before the turbo is restrictive, the inlet pressure could be higher than atmospheric if there is more than 1 turbocharger in series. In that case the inlet let pressure will be the outlet pressure of the turbo before it. If we want 10 psi of boost with atmospheric pressure as the inlet pressure, the formula would look like this:
(10 + 14.7) ÷ 14.7 = 1.68:1 pressure ratio
le reste, c'est de la thermo, en pratique on ne s'en sert pas trop pour déterminer un turbo, car il faut enir compte de l'offre du marché ...
Temperature Rise
A compressor will raise the temperature of air as it compresses it. As temperature increases, the volume of air also increases. There is an ideal temperature rise which is a temperature rise equivalent to the amount of work that it takes to compress the air. The formula to figure the ideal outlet temperature is:
T2 = T1 (P2 ÷ P1)0.283
Where:
T2 = Outlet Temperature °R
T1 = Inlet Temperature °R
°R = °F + 460
P1 = Inlet Pressure Absolute
P2 = Outlet Pressure Absolute
Lets assume that the inlet temperature is 75° F and we're going to want 10 psi of boost pressure. To figure T1 in °R, you will do this:
T1 = 75 + 460 = 535°R
The P1 inlet pressure will be atmospheric in our case and the P2 outlet pressure will be 10 psi above atmospheric. Atmospheric pressure is 14.7 psi, so the inlet pressure will be 14.7 psi, to figure the outlet pressure add the boost pressure to the inlet pressure.
P2 = 14.7 + 10 = 24.7 psi
For our example, we now have everything we need to figure out the ideal outlet temperature. We must plug this info into out formula to figure out T2:
T1 = 75
P1 = 14.7
P2 = 24.7
The formula will now look like this:
T2 = 535 (24.7 ÷ 14.7)0.283 = 620 °R
You then need to subtract 460 to get °F, so simply do this:
620 - 460 = 160 °F Ideal Outlet Temperature
This is a temperature rise of 85 °F.
Adiabatic Efficiency
The above formula assumes a 100% adiabatic efficiency (AE), no loss or gain of heat. The actual temperature rise will certainly be higher than that. How much higher will depend on the adiabatic efficiency of the compressor, usually 60-75%. To figure the actual outlet temperature, you need this formula:
Ideal Outlet Temperature Rise ÷ AE = Actual Outlet Temperature Rise
Lets assume the compressor we are looking at has a 70% adiabatic efficiency at the pressure ratio and flow range we're dealing with. The outlet temperature will then be 30% higher than ideal. So at 70% it using our example, we'd need to do this:
85 ÷ 0.7 = 121 °F Actual Outlet Temperature Rise
Now we must add the temperature rise to the inlet temperature:
75 + 121 = 196 °F Actual Outlet Temperature
Density Ratio
As air is heated it expands and becomes less dense. This makes an increase in volume and flow. To compare the inlet to outlet air flow, you must know the density ratio. To figure out this ratio, use this formula:
(Inlet °R ÷ Outlet °R) × (Outlet Pressure ÷ Inlet Pressure) = Density Ratio
We have everything we need to figure this out. For our 350 example the formula will look like this:
(535 ÷ 656) × (24.7 ÷ 14.7) = 1.37 Density Ratio
Compressor Inlet Airflow
Using all the above information, you can figure out what the actual inlet flow in in CFM. Do do this, use this formula:
Outlet CFM × Density Ratio = Actual Inlet CFM
Using the same 350 in our examples, it would look like this:
516.5 CFM × 1.37 = 707.6 CFM Inlet Air Flow
That is about a 37% increase in airflow and the potential for 37% more power. When comparing to a compressor flow map that is in Pounds per Minute (lbs/min), multiply CFM by 0.069 to convert CFM to lbs/min.
707.6 CFM × 0.069 = 48.8 lbs/min
Now you can use these formula's along with flow maps to select a compressor to match your engine. You should play with a few adiabatic efficiency numbers and pressure ratios to get good results. For twin turbo's, remember that each turbo will only flow 1/2 the total airflow
Les map ...
[Image: compressormap.gif]
Operating characteristics: The compressor operating behaviour is generally defined by maps showing the relationship between pressure ratio and volume or mass flow rate. The useable section of the map relating to centrifugal compressors is limited by the surge and choke lines and the maximum permissible compressor speed.
Surge line: The map width is limited on the left by the surge line. This is basically "stalling" of the air flow at the compressor inlet. With too small a volume flow and too high a pressure ratio, the flow can no longer adhere to the suction side of the blades, with the result that the discharge process is interrupted. The air flow through the compressor is reversed until a stable pressure ratio with positive volume flow rate is reached, the pressure builds up again and the cycle repeats. This flow instability continues at a fixed frequency and the resultant noise is known as "surging".
Choke line: The maximum centrifugal compressor volume flow rate is normally limited by the cross-section at the compressor inlet. When the flow at the wheel inlet reaches sonic velocity, no further flow rate increase is possible. The choke line can be recognised by the steeply descending speed lines at the right on the compressor map.
En rapide, il faut se placer dans la zone du milieu ( neta is V c'est le rendement isentropique du compresseur.
Cela suppose d'avoir déterminé abscisses et ordonnées, là je ne sais pas à quel turbo correspond cette map, il est surement pas très gros vu les vitesses de saturation.
Bon c'est de la bonne méca flux, mais c'est assez chiant et en plus ya pas mal d'approximations (surtout ici), donc ...
Bien evidemment il y a des tas d'autres choses à prendre en compte (efficacité volumétrique etc), voila pourquoi en pratique le choix se fait dabord par rapport à l'offre et aux objectifs.What turbo should i run
s
Muad-Dib Hors ligne
Sujets : 85
30-06-2006, 18:20:20   -
lien de streetbike:
http://www.turbobygarrett.com/turbobygar...ch103.html
Kizashi and Swift GTI SF powered
Alvogadron Hors ligne
03-07-2006, 13:11:53   -
Généralement les "map" sont exprimées en rapport de pression sur débit massique (kg/s) et non volumique (m3/s) comme c'est le cas ici.
Le rapport des pressions est le rapport : Pression entrée compresseur / pression sortie compresseur.
En revanche, et c'est la même chose ici, on supperpose la courbe "pleine charge" du moteur (la fameuse que je cherchais). Elle aussi est déterminée en rapport de pressions/débit massique que le moteur est capable d'absorber. La difference avec le debit volumique est que la masse d'air n'est pas proportionnelle au régime moteur.
Du coup, à la "map", on supperpose une courbe qui est en 2 parties :
- la premiere est du type y=ax
- arrivé au couple maxi du moteur, la seconde pointe le bout de son nez et est du type y=constante (grosso modo pour un moteur a combustion interne automobile).
Les points de couple max et puissance max doivent se trouver dans la surface de rendement maxi du compresseur et ne surtout pas sortir vers la "surge limit" (limite de pompage) qui induirait un risque de casse du compresseur.
http://www.bms-racing.fr.st
Vends echangeurs air / air => mp
Vends toutes pieces nissan 100nx => mp
rodi Hors ligne
Sujets : 106
21-10-2006, 17:32:02   -
alors la suite comment sa marche .....
il faut faire quoi , tracer la courbe pression/débit du moteur "origine"sur la map de la turbine en question??
et pour le compresseur on fait quoi???
pour les calculs de débits corrigé faut des sondes a l'échappement ( pression+temp)
rodi Hors ligne
Sujets : 106
22-10-2006, 16:55:23   -
personne pour répondre ????????????????
05-11-2006, 20:53:19   -
rodi a écrit :personne pour répondre ????????????????
meuhh si.
On va prendre depuis le debut.
Quand on adapte un turbo sur un moteur, atmo ou deja compresssé, il faut se fixer une puissance voulue avec ce que l'on a (style, un moteur 1809cm3), savoir ce que l'on veut : à quel regime le turbo doit il souffler? Veut on faire du circuit (puissance maxi la plus elevée) ou du rallye (plage d'utilisation la lus etendue)? Et enfin, à quelle pression (maxi) le turbo va t il tourner?
Apres avoir defini son objectif il faut passer à la partie calcul. Je n'entrerais pas dans les détails mais il faut savoir que les facteurs de puissance recherchée, de régime de puissance et de richesse entrent en compte.
Prenons un graphe compresseur (la "map" ca fait plus-mieux-bien) :
[Image: GT2554R_471171_3_comp_e.gif]
en ordonnées nous avons les rapport des pressions sortie sur entrée compresseur. Prenons Pa = 1.015 b
Admettons que l'on veuille 1.0bar de pression.
Donc le rapport serait de (1.0+1.015)/1.015 = 1.985
Oui mais il y a des pertes en entrée compresseur avec le filtre à air.
Donc Pentrée comp environ = 0.95 b
Donc le rapport est : (1.0 + 1.015)/0.95 = 2.12
Nous savons déjà où bosser sur les ordonnées : 2.12
Vient le tour des absisses. Plus compliqué car il faut faire les calculs nécessaires à la prépa avec ces facteurs :
- chevaux recherchés
- cylindrée
- tours/min max
- conditions ambiantes (T°C et Pression atmo)
- l'essence nécessaire pour chaque cheval (exprimés en poids/(chevaux x heures)
- le rapport A/F (richesse du mélange)
On en déduit le débit massique que le moteur devra avoir pour la puissance maxi. Disons 20lb/min pour l'exemple et 5000tr/min.
On a le rapport de pressions.
On a le débit qu'il faut pour nos hp max.
Il n'y a plus qu'à y reporté sur le graphe (ici un garett GT2554R).
Pour notre Pmax à 5000 tours, on se retrouve dans un rendement compresseur d'environ 70% ce qui est pas mal.
Il faudra continuer les calculs aux régimes de 3000tr/min et jusqu'à la rupture, puis les mettre sur le graphe afin de vérifier qu'aucuns points de fonctionnement du moteur ne sorte de celui ci. En evitant à tout prix la "surge limit" ou limite de pompage, fatale pour les pales du compresseur.
Pour cet exemple j'ai tout prit au pif et n'a rien a voir avec le ca18det.
Les calculs doivent etre reportés sur plusieurs graphes afin de determiner quel compresseur sera le mieux (celui qui fonctionnera le plus souvent à son rendement le plus élevé).
Vient ensuite la partie turbine où l'on jouera sur l'A/R afin de déterminer à quel régime le turbo accrchera. Ce choix devra etre lié au choix du compresseur bien sûr.
rodi Hors ligne
Sujets : 106
04-12-2006, 08:30:35   -
j'ai trouvé un site avec tout les maps (t25 compris lol)
http://not2fast.wryday.com/turbo/maps/
et un autre qui fait le graphe sur la map à partir de la puissance désirée(aussi avec la cylindré):
http://www.squirrelpf.com/turbocalc/index.php
Fred 62 Hors ligne
05-12-2006, 20:06:50   -
pas mal d'infos ici !
http://www.stealth316.com/2-turboguide.htm
http://www.stealth316.com/2-3s-compflowmaps.htm
un exemple en fonction de la pression !
http://www.stealth316.com/images/td05h-1...c100ve.gif
une map sans opttimisation moteur, et avec !
là c'est flagrant niveau comprehension !
regardes les plages d'utilisation a meme pression !
http://www.stealth316.com/images/engineflowcomparo2.gif
bon, enfin, ça aide a comprendre !
fred
"Donnes le meilleur de toi meme en toutes circonstances"
[Image: baliere.jpg]
[url=www.wicar.net][img]
rodi Hors ligne
Sujets : 106
06-12-2006, 13:45:00   -
dommage que les photos ne s"affichent pas
Sujets : 129
06-12-2006, 14:41:12   -
+1 pas de tof Cry
DAV4WS En ligne
Mineur de corde
Sujets : 39
24-10-2016, 15:06:24   -   RE: [FAQ Nissan] Calcul map turbo
déterrage powa ! ! coucou pas trop compris je suis dedans en ce moment le site garrett propose de faire les calcul mais n'y arrive pas :
https://www.turbobygarrett.com/turbobyga...webadviser
si vous avez des calculateurs pour je suis preneur merci Wink
vais faire un montage avec bride T2( sur prelude 3g Smile
A++
4WS trajectoire assuré !
-ma prelude full OEM ici
-3G 4WS 260Nm race ici
-ma moto ici
-ma toy TA23
toutes pieces /réparations /préparations de prelude 3G en MP
(Modification du message : 24-10-2016, 15:06:41 par DAV4WS.)
Yaya 16v Hors ligne
Z32TT-EJ1 chandelles
60 - Oise France
Réputation : 15
24-10-2016, 15:51:22   -   RE: [FAQ Nissan] Calcul map turbo
http://beauceperformance.tuningboard.net...-son-turbo
DAV4WS En ligne
Mineur de corde
Sujets : 39
25-10-2016, 12:08:05   -   RE: [FAQ Nissan] Calcul map turbo
superbe c'est bien expliqué avec des formule simplifié j'en suis au lb/min
je copie colle ici:
""Explication détaillé pour savoir comment choisir son turbo
Message forgues le Ven 2 Mai - 10:42
Choisir la taille de turbo pour matcher votre moteur n'est pas si difficile. Vous devez d'abord trouver quelques informations au sujet de votre moteur, décidez combien de boost vous voulez employer, et puis vérifier l'information avec la map de compression d'un turbo. Il y a un peu de maths impliquées, mais c'est facile (surtout quand on a les formules bien expliquée!).
Premièrement vous devez savoir le "CFM" (cubic feet per minute) de votre moteur en aspiration naturelle ou N/A (c'est-à-dire, sans turbo ou suralimentation).
Vous devez premièrement trouver le CID (Cubic Inch Displacement) du moteur ...
Il y a 2 moyens, prendre le CC (centimètres cube) et le convertir en pouce cubes ou prendre la formule complète qui est de calculer le bore et le stroke, mais puisque les deux formules donnent des résultats TRÈS similaires, nous allons dons utiliser la formule des CC puisque c'est un nombre pratiquement omniprésent sur les infos d'un moteur.
1CC = .06102 CID
la formule est donc :
CC x 0.06102 = CID
Pour le Beta c'est
1975 x 0.06102 = 120.51 CID
L'autre formule pour ceux qui la veulent :
Bore x Bore x .7854 x Stroke x Nombre de Cylindre = Cubic Inch Displacement (CID)
Maintenant que nous avons le CID nous pouvont passer à la formule suivante, trouver le CFM :
Volume d'air (CFM) = (RPM x CID) / 3456
Donc, pour calculer le volume d'air aspiré par le moteur (CFM) vous devez multiplier votre peak RPM avec le déplacement en pouce cubes de votre moteur (CID) ensuite, vous devez diviser ce nombre par 3456.
Pour notre moteur, le Beta :
(6500 x 120.51) / 3456 = (783315) / 3456 = 226.653 CFM
Un moteur Beta a donc besoin de 226.653 Pieds cubes d'air par minute à 6500 tours par minutes en aspiration naturelle. Maintenant nous savons les besoins de volume d'air N/A, mais afin de lire une map de compression, nous devrons figurer le flux d'air en livres par minute (lb/min) requis par notre moteur sous la poussée. Pour notre exemple, employons une pression de 10psi.
En ce moment il est important de parler de la différence entre la pression absolue (psia) et la pression indiquée. Le niveau de poussée que vous lisez sur votre gauge de boost s'appelle vraiment psig ou Pound per Square Inch Gauge. La pression absolue est 14.7 + psig. Le 14.7 vient de la pression d'air au niveau de la mer. Ainsi 10psig = 24.7psia.
Nous pouvons trouver les conditions de notre moteur en appliquant nos nombres à la loi idéale de gaz. La loi idéale de gaz relie le volume, la pression, la température et la masse d'air. Elle est :
PV = nRT
P = pression absolue,
V = volume CFM,
n est relié à la masse,
R est une constante
et T est la température de l'air en unité de mesure Rankine.
Simplifions la loi idéale de gaz pour trouver le flux d'air requis de notre moteur dans lb/min avec le boost a 10psi. Nous devrons savoir la température d'air comprimé sortant du turbo. Supposons qu'intercoolé la température d'air aspiré environ de 130F. Les voitures Turbo qui n'ont pas un intercooler peuvent voir les températures de l'air aspiré grimper autour de 250F. Pour obtenir la température en Rankine, il faut simplement additionner 460 à la température de l'air en fahrenheit.
n(lb/min) = ((14.7 + psig) x V cfm x 29) / (10.73 x T deg) R
Donc avec les chiffres d'un Beta on obtient ;
n(lb/min) = ((14.7 + 10) x 226.653 x 29) / 10.73 x (130 + 460)R
n(lb/min) = (24.7 x 226.653 x 29) / 10.73 x 590R
n(lb/min) = 162351.5439 / 6330.7
n(lb/min) = 25.6451lb/min
Nous trouvons donc qu'idéalement, notre Beta aura besoin de 25.64lb/min d'air avec un boost de 10psi à 6500RPM. Je dis idéalement parce que cela suppose que notre moteur a une efficacité volumétrique de 100%. Nous supposerons que nos moteurs ont une efficacité volumétrique environ de 85%. Maintenant nous pouvons corriger notre flux d'air.
25.6451 x .85 = 21.798lb/min
D'ailleurs, en général, je dis bien en général, la puissance en HP peut être trouvées par la formule qui suit :
HP = lb/min x 10 = 21.789 x 10 = 217.89HP
Maintenant que nous connaissons notre flux d'air requis en lb/min, nous devons trouver quelque chose appelée un rapport de pression. C'est le rapport entre l'admission de la pression et la pression à la sortie du compresseur. La pression d'admission est habituellement 14.7psi. (pression barométrique standard au niveau de la mer) la pression de sortie est 14.7psi + boost. Prendre le rapport des deux et vous obtenez :
Ratio de pression = (14.7 + boost) / 14.7
Pour notre projet virtuel nous avons décidé booster a 10psi ...
Ratio de pression = (14.7 + 10) / 14.7 = 24.7 / 14.7 = 1.68
Nous avons maintenant toute l'information avec laquelle nous pouvons lire une map de compression. Les cartes montrent l'efficacité et les courbes de RPM pour le compresseur. Afin de lire les cartes, trouver simplement le rapport de pression sur l'axe des Y et suivre sur la map jusqu'au point de rencontre du flux d'air du moteur (lb/min ... 21.798 dans notre cas).
Il est possible que le flow map que vous avez ne soit pas en lb/min., dans ce cas voici les formules de conversions pour les autres mesure (CFM et m3/sec.)
1 m3/s = 2118.88 cfm
10 lb/min = 144.718 cfm
10 lb/min = 0.0683 m3/s
Il est souhaitable de faire joindre nos donées bien au milieu du graphique, bien que quelque chose jusqu'a aussi bas que 60% fonctionne.
Exemple de "Compressor flow maps" (on voit que le Garrett GT28rs @ 62trim est beaucoup plus efficace que le 14b de Mitsu, donc le Garrett produira plus de HP)
Nous avons parlé beaucoup au sujet du côté de compresseur du turbo, maintenant se tournons vers le côté de la turbine. Nous avons pouvons trouver un turbo qui fonctionneras bien avec les infos de notre moteur, mais es-ce qu'il va "spooler" ? Cela dépend du "area ratio" ou A/R, du turbine housing, et de la taille de turbine. Une plus grande roue de turbine soopleras plus lentement qu'une petite. Une plus grande turbine fera plus de puissance, mais le boost arriveras plus tard, peut-être quand la course sera terminé?
A/R
L'autre chose à considérer est le A/R. Elle détermine quand la turbine spool. Le turbine housing A/R est la section du turbine housing divisé par la distance du centre de cette section au centre de la roue. Ca fait plus de sens si on regarde le graphique.
Si vous prenez par exemple, le secteur A1 et le divisent par R1, vous aura trouvé le A/R du turbine housing. Chaque section transversale et rayon ont les mêmes proportions ainsi le A/R sera trouvé en employant n'importe quels section/rayon.
Les A/R des turbine housing sont habituellement .58, .69, .81, .96 et 1.00. La turbine vas "spooler" plus tôt avec un .58 A/R, et plus tard avec un 1.00 A/R. Le retard sera un problème si le A/R trop grand, mais s'il est trop petit, le turbo manquera de d'air et ne sera rien de plus qu'une restriction.
Le Trim
Le trim pour une roue de compresseur ou de turbine est le rapport carré du diamètre plus petit divisé par le diamètre plus grand, multiplié par 100. Les roues de turbocompresseur ont un grand et de faible diamètre. Sur le compresseur, le diamètre est l'inducteur et le grand diamètre est l'exducer. C'est l'inverse pour la roue de turbine.
Trim du Compresseur = ((inducteur x inducteur) x 100) / (exducer x exducer)
Trim de la turbine = ((exducer x exducer) x 100) / (inducteur x inducteur)
Pour des roues de compresseur, donné une taille constante d'exducer, plus le trim est grand, plus la roue coule mieux. Cela signifie également que la roue a une efficacité légèrement inférieure. Pour les roues de turbine, donné un inducteur constant, un plus grand trim signifie que la turbine a un meilleur flow avec moins de backpressure. Ca signifie également que moins d'énergie est récupérée de l'échappement du moteur ralentissant le temps spool.
J'espère que ce n'est pas trop complexe et que cela pourra vous aider a trouver votre bon turbo et aussi vous donner des idées pour des setup turbo!
Chiffres et formules a retenir ;
CC x 0.06102 = CID
CFM = (RPM x CID) / 3456
intercooled (lb/min) = ((14.7 + boost) x CFM x 29) / 10.73 x (130 + 460)R
non intercooled (lb/min) = ((14.7 + boost) x CFM x 29) / 10.73 x (250 + 460)R
Beta stats ;
CID = 120.51
CFM = 226.653 @ 6500RPM (N/A)
Specific PSI with corresponding Air Flow;
10psi = 21.798lb/min // 315.456GFM (85% d'efficacité de flow)
12psi = 23.563lb/min // 340.999CFM (85% d'efficacité de flow)
15psi = 26.211lb/min // 379.320CFM (85% d'efficacité de flow)
20psi = 30.623lb/min // 443.170CFM (85% d'efficacité de flow)
source : http://www.junkyardturbos.com
Liens pour les "compressor maps" (il existe d'autres sites)
http://64.225.76.178/catalog/compmaps/fig1.html
http://www.turbobygarrett.com/turbobygar...rgers.html
Une précision pour ceux qui sont mauvais en mathématique
Lorsqu'il est question de trouver le flux d'air requis par le moteur, on part à partir de cette formule:
PV = nRT
Il faut isoler (mettre seul) la variable n (n est relié à la masse, le lb/min)
Ce qui transforme la formule comme ceci:
n = PV/TR
c'est ce que nous voyons dans la suite de l'explication:
n = ( P x V ) / ( T x R )
Bon calcul""
-ma moto ici
-ma toy TA23
DAV4WS En ligne
Mineur de corde
Sujets : 39
26-10-2016, 17:49:24   -   RE: [FAQ Nissan] Calcul map turbo
bon j'ai tout lu mais n'arrive pas a faire ma courbe meme avec les valeurs de calcul !
:/ sniff
-ma moto ici
-ma toy TA23
Sujets apparemment similaires...
  [ECU] FUEL map, VE map, etc... questions ! Natraya 18 4 690 02-12-2009, 19:09:11
Dernier message: faburisu
  FAQ NISSAN : Preparation moteur 200sx s13 sebar 41 18 916 20-08-2008, 15:20:26
Dernier message: 80franck
  [FAQ Nissan] Cablage des feux kouki sur s13 Anonymous 18 15 520 24-01-2007, 21:08:37
Dernier message: Anonymous
  [FAQ Nissan] Changement de turbo a la maniere sur 300zx Maceo 11 14 752 10-10-2006, 10:21:42
Dernier message: Muad-Dib
  [FAQ Nissan] Installation mano T° huile / pression huile Ludo_fC3S 163 32 296 17-06-2006, 21:55:34
Dernier message: Jack-of-all-Trades
  [FAQ]Durites turbo eau huile Muad-Dib 27 2 718 17-04-2006, 14:57:05
  map turbo 300zx wrc 13 1 602 10-02-2006, 18:27:24
Dernier message: wrc
  [FAQ Nissan] Mecanique: Bielles S13 Ludo_fC3S 33 10 676 22-12-2005, 20:37:22
Dernier message: SK_Flowne
  [FAQ Nissan] Nissan 300ZX tibo 1 10 590 16-12-2005, 21:27:51
Dernier message: tibo
  [FAQ Nissan] Nissan 200SX Goose 26 58 133 16-12-2005, 21:03:26
