[FAQ] S14 Fuel pump needed?
grumly2000 Hors ligne
Sujets : 99
04-02-2005, 18:45:45   -   [FAQ] S14 Fuel pump needed?
Voilà en regardant un peu en détail ceci:
http://www.sxoc.co.uk/vbb/showthread.php...ge=4&pp=20
extrait:
Citation :OK, the figures below arent hard fact, and will vary car to-car, but lets take the things in order of being "maxed out" ... dont think anyone could argue with the order even with differance of opinion on figures.
Generally (12psi) 240bhp is OK on std pump & plugs
At (13psi)250bhp fuel pump may cause lean running @ 7K in 5th on WOT
At 14psi (260bhp)fuel pump may cause lean running @ 6.5K in 5th on WOT
At 14psi your WMIC is in danger of overheating after 1 minute flat out .. (that may not seem a long time, but consider standing 1/4 to 100mph takes 14secs ...)
At 15psi (270BHP) your injectors are @ 90%
At 18psi (310BHP) your T28 is maxed.
RR with full fuelling and setup cheack are one of the few ways to get 95% peice of mind ... but this is not 100% safe if it happens to be a 30oC hot summers day when you do your top speed run......or your fuel filter starts to block / muck from your tank blocks your pickup sock (this happened with my old volvo, wouldnt go up hills, couldnt supply the fuel) NOTHING is 100% safe, not even a 100% standard car.
et ceci:
http://www.sxoc.co.uk/vbb/showthread.php...ge=2&pp=20
ben du coup j'ai encore craqué et j'ai pris un wahlbro :'(
http://grumly2000.labrute.fr
Greg_P Hors ligne
04-02-2005, 19:29:29   -
Oublie pas le masque pdt l'installation, ou bien 4 aspirine quand tu as fini...
---->>> MP!!!! <<<----------
Sujets : 99
04-02-2005, 19:51:30   -
Oui t'inquiètes pas; j'ai déjà du remettre par 2 fois ma jeauge à essence suite à des sorties circuit...musclées :]
Donc du coup j'ai du faire ça alors que le réservoir était au 3/4; et j'ai halluciné mais l'essence ça attaque la peau :o
A des moments comme j'ai du me rincer le bras dans l'eau car j'avais la peau rouge de l'essence qui me brulait :o
Tsuchiya Hors ligne
Sujets : 86
04-02-2005, 23:58:48   -
grumly2000 a écrit :Oui t'inquiètes pas; j'ai déjà du remettre par 2 fois ma jeauge à essence suite à des sorties circuit...musclées :]
:roll: quel idée c'est évident que l'essence ca brule, la question est pourquoi tu y as mis le feu!!!:]
ok je sort
Piaf
  [ECU] FUEL map, VE map, etc... questions ! Natraya 18 7 497 02-12-2009, 19:09:11
Dernier message: faburisu
  probleme de fuel cut sur s13 speederman 12 3 038 12-10-2008, 22:10:58
Dernier message: BiSBAR
  ratio air fuel ludocrx52 8 1 354 15-09-2007, 01:11:40
Dernier message: folken
  comment cabler la gauge air/fuel?! johny_013 20 6 198 15-12-2006, 10:44:36
  cone pour S14 montable sur S13 (mesure entraxe vis needed rodi 12 2 958 14-11-2006, 14:18:33
  [200SX - CLIMATISATION] Expert en clime needed Asphalt Burner 56 8 340 29-09-2006, 22:15:57
Dernier message: Kisskool57
  fuel cut??? jovicaS13 19 2 859 18-04-2006, 13:09:56
  Fuel cut defencer c'est quoi? Bubuche 11 3 228 11-04-2006, 23:27:03
Dernier message: Maxthekiller
  explications needed, fusible et démarrage Muad-Dib 3 1 246 20-03-2006, 23:06:16
  fuel cut s14 et pique de pression warrior 13 1 864 13-02-2006, 21:59:39
Dernier message: warrior
