[ej2] ratés moteur a 1700 tours
daves Hors ligne
04-08-2011, 12:42:47   -   [ej2] ratés moteur a 1700 tours
bonjour a tous, je viens vers vous car j ai un souci que je n arrive pas à régler,voilà depuis pas mal de temps j ai mon voyant moteur qui reste allumé et j ai des ratés moteur a 1700 tours /mn ,il y a quelques temps j ai remplacé mon moteur suite a un cylindre hs et je pensais que ce problème serais réglé mais il n'en est rien.J ai fait la manip pour avoir le code panne et cela m'indique donc voyant allumé une fois et ensuite 4 court. Quelqu'un aurait il une idée d'ou cela pourrait provenir?????? merci d avance de vos réponses.
à bientot Wink
CharlyCRX Hors ligne
AS53 EE4 ED9 FK3
13 - Bouches-du-Rhône France
04-08-2011, 13:02:07   -
Code 4 - Crank Angle Sensor
Top sensor in the dist. and is used for fuel control and misfire detection.
If the dist. base bearing starts failing, it will start heating the sensor(s) up, destroying the magnetism causing a code(s). It will lose 10% of it's strenght, each time it is heated up, to a 170 degrees plus.
In most cases, replacing the distributor is the only alternative. Especially if the bearing has failed.
Honda does don't stock the bearing itself, but other after-market compaines are said to have one.
If you have problems starting the engine, or drivability after the install check your cam aligment. The seizing bearing might have caused it to jump a tooth/notch or two. From the extra drag due to the bearing failing.
Code 14 - Electronic Air Control Valve
Lets extra air into the intake manifold, to help control the idle under different loads.
Check the O-rings, for mountng condition.
Clean the inside of the Valve after removing, using any kind of solvent that will remove carbon build up. By spraying it inside the two holes ect...
Place the flat end of a screw driver on the EACV while the engine is running. Place the handle against your ear and listen. Should hear something in there jumping back and fourth at a rapid rate.
EACV Sensor Wires:
1 Blue/Black
1 Yellow/Black
A toi de trouver !
daves Hors ligne
04-08-2011, 13:19:41   -
mdr meme avec google traduction j ai rien compris , par contre une question bete es ce que le filtre a essence pourrait me faire ce genre de truc?
AS53 EE4 ED9 FK3
04-08-2011, 13:20:09   -
si y'a un code erreur à l'ECU... difficile.
traduction :
Solution 1 : essayer avec un autre allumeur,
Solution 2 : changer les joints et nettoyer/changer l'EACV (starter automatique).
daves Hors ligne
04-08-2011, 13:58:13   -
voila c'est cela qui es bizarre car quand jai remplcé le moteur toutes ces pieces on été remplacer en meme temps car c'étais un moteur complet avec tout dessus.
AS53 EE4 ED9 FK3
04-08-2011, 14:09:01   -
ben justement... les équipements moteurs ont peut etre une défaillance par rapport à ton équipement avant de changer le moteur.
daves Hors ligne
04-08-2011, 14:17:31   -
justement j avais le même souci auparant avec l ancien moteur.
AS53 EE4 ED9 FK3
04-08-2011, 14:40:16   -
alors ça vient de ton faisceau.
daves Hors ligne
04-08-2011, 20:40:46   -
je vais me pencher la dessus alors
merci a toi Charly.
yukio-sama Hors ligne
MX5/GT86/RAM'85
84 - Vaucluse France
05-08-2011, 01:34:09   -
Question, lors du changement du moteur est-ce que tu as fais un reset de l'ecu? Sa peut peut être venir de la.
Si oui, alors effectivement il y a de grande chance que ce soit le faisceau Wink.
  [EJ2 / EJ6] Différence tambours EJ2 / EJ6 GC106XT 2 1 845 17-04-2013, 10:58:14
Dernier message: GC106XT
  [EG6] A chaud, à coups moteur, ratés d'allumage Redbull 2 3 501 15-01-2013, 11:15:25
Dernier message: Redbull
  [Ej2-Eg4]Shema faisceau ecu habitacle ej2 et eg4 Cityhunter72 19 8 237 25-08-2012, 12:12:53
Dernier message: rere33140
  [Ej2] liberer un ej2 et ameliorer le chassis romain76 6 1 980 30-03-2012, 11:32:25
Dernier message: redrix
  [GF-Ek2-EL] Ratés Moteur D13B à chaud : résolu Dark-Buster 31 11 414 30-08-2011, 02:22:54
Dernier message: vtecman34
  [d16a9] ratés pendant accélérations franches... Mugen34 11 2 634 01-05-2011, 16:46:13
Dernier message: Mad Manu
  [ EG9 ] Gros ratés aprés montage turbo, Rival 40 6 552 18-02-2011, 16:06:07
Dernier message: red_one
  [EC9] Ratés broute petarrade a froid uniquement - RESOLU bruno006 16 7 932 04-02-2011, 20:19:52
Dernier message: Datajunkie
  [D16A9] ratés à bas régimes... à chaud skanarchye 2 1 950 28-11-2010, 17:11:31
Dernier message: raphy76
  [B16]: Ratés d'allumage =>Défaut de masse?[RESOLU] ludoracingteam 12 5 598 24-11-2010, 08:33:01
Dernier message: ludoracingteam
