[FAQ] 200SX Spring Rate
Auteur Message
grumly2000 Hors ligne
Sujets : 101
04-04-2005, 18:23:47   -   [FAQ] 200SX Spring Rate
Spring Rate Archive
User: WeST
In order to convert kg/mm to lb/in do the following. Multiply the kg/mm amount by 56. So if you kg/mm spring rate is 6 kg/mm Front and 5 kg/mm Rear your lbs/in would be 336 lb/in Front and 280 lb/in Rear. Pretty Simple.
Below is a archive of Spring Rates for various stock and aftermarket springs for the s13 and s14. Enjoy, Please post any additions you may have to this list. Thanks!
s13 Springs
Stock 1992 (from FSM)
Front & Rear: 102 lb/in 1.8kg/mm
Front & Rear: 110 lb/in w/ HICAS 2.0 kg/mm
Stock 1990 (from FSM):
Front & Rear: 112 lb/in (base) 2.0 kg/mm
Front & Rear: 123 lb/in (sports package) 2.2 kg/mm
KGMM S21 Sport (Black)
Front: 3.2 kg/mm | 179.2 lb/in
Rear: 2.6 kg/mm | 145.6 lb/in
KGMM S21 SuperSport (Blue)
Front: 4.6 kg/mm | 257.6 lb/in
Rear: 3.8 kg/mm | 212.8 lb/in
KGMM S21 Racing (Silver/Gold)
Front: 6.6 kg/mm | 369.6 lb/in
Rear: 5.2 kg/mm | 291.2 lb/in
Eibach ProKit (Progressive)
Front: 114-200 lb/in | -1.8"
Rear: 114-148 lb/in | 1.6"
Eibach Sportlines (Progressive)
Front: 137-230 lb/in | 2.2"
Rear: 128-200 lb/in | 2.1"
H & R Sport (Progressive)
Front:2.0-2.08kg/mm | 112~116 lbs/in | -1.3"
Rear: 2.5-2.6kg/mm | 140~145 lbs/in | -1.3"
RSR Race Springs
Front: 279 lb/in | 1.4"
Rear: 251 lb/in | 1.2"
RSR Down
Front: 3.0 kg/mm | 167 lbs/in | 1.5" Est.
Rear: 3.0 kg/mm | 167 lbs/in | 1.2" Est.
Tokico
Front: 3.0 kg/mm | 169 lbs/in | -1"
Rear: 2.7 kg/mm | 150 lbs/in | -1"
TANABE GF210 (Grip Feeling)
Front = 2.9 kg/mm | 162 lb/in | -30to -40mm
Rear = 2.7 kg/mm | 151 lb/in | -15 to -25mm
Suspension Techniques: 1.3" drop
Front: 206 lb/in | 1.3"
Rear: 155 lb/in | 1.3"
Tein S.Tech
Front = 3.2 kg/mm | 179 lb/in
Rear = 2.9 kg/mm | 162 lb/in
5Zigen R-Rate (Progressive)
Front = 2.4-5.2 kg/mm | 134-291 lb/in | 1.3"
Rear = 1.9-5.0 kg/mm | 106-280 lb/in | 1.1"
S13 Coilovers
Nismo S-Tune (not height adjustable)
Front: 5.3 kg/mm | 296 lb/in
Rear: 3.9 kg/mm | 218.4 lb/in
Nismo N1
Front: 8/10/12 kg/mm | 448 - 672 lb/in
Rear: 8 kg/mm | 448 lb/in
Tein HA
Front = 6 kg/mm | 336 lb/in
Rear = 5 kg/mm | 280 lb/in
Tein HE
Front = 8 kg/mm | 448 lb/in
Rear = 6 kg/mm | 336 lb/in
Tein RA _
Front = 10 kg/mm | 559 lb/in
Rear = 8 kg/mm | 448 lb/in
Tein RE
Tein RS
Tein FLEX
Front = 5 kg/mm | 280 lb/in
Rear = 4 kg/mm | 224 lb/in
Zeal Function B-6
Sreet Spec:
Circuit Spec:
Rear = 7 kg/mm | 392 lb/in
S14 Springs
KGMM DR21
Front = 4.8-3.0 kg/mm | 269-168 lb/in
Rear = 4.0-2.8 kg/mm | 224-157 lb/in
KGMM DR21 Racing (Silver/Gold)
Front = 6.6-3.2 kg/mm | 370-179 lb/in
Rear = 5.2-2.4 kg/mm | 291-134 lb/in
RSR Hard Springs
Front = 5.0 kg/mm | 280 lb/in
Rear = 4.2 kg/mm | 235 lb/in
TANABE SuperH
Front = 3.0 kg/mm | 168 lb/in | -28mm
Rear = 4.0 kg/mm | 224 lb/in | -9mm
TANABE DF210 (Dress Form)
Front = 4.7 kg/mm | 263 lb/in | -30to -40mm
Rear = 4.7 kg/mm | 263 lb/in | -15 to -25mm
Front = 2.8 kg/mm | 157 lb/in | -30to -40mm
Rear = 3.0 kg/mm | 168 lb/in | -15 to -25mm
TRUST Sport Springs
Front = 2.6 kg/mm | 146 lb/in | -25mm
Rear = 2.6 kg/mm | 146 lb/in | -25mm
HKS Super Sports
Front = 4.14 kg/mm | 232 lb/in
Rear = 3.46 kg/mm | 194 lb/in
Tein S.Tech
Front = 4.8 kg/mm | 269 lb/in
Rear = 4.4 kg/mm | 246 lb/in
s14 Coilovers
Apexi N-1 Coilovers
Tein HA kg/mm
Tein HE
Tein RA
Tein RE
Tein RS
Tein FLEX
Zeal Function B-6
Sreet Spec:
Circuit Spec:
taked from http://www.zilvia.net/faqs/archive/springrates.asp
http://grumly2000.labrute.fr
To those of you who received honors, awards and distinctions, I say: "Well done!". And to the C students, I say: "You, too, can be president of the United States!".
George W. Bush (Yale speech, 2001)
Greg_P Hors ligne
Sujets : 42
05-04-2005, 11:03:00   -
Tu as le tarage d'origine des S14?
[Image: GS_ef9a881fe345b7edf2e52c9cbd28f7a2.png]
VEND MANO VDO 52mm noir avec sondes: Tempe, pression d'huile, tempe d'eau, voltmetre.
---->>> MP!!!! <<<----------
sepi Hors ligne
Sujets : 33
05-04-2005, 12:44:43   -
Oui, celui d'origine et le post vole en FAQ Wink
Ben en tt cas, les ressorts en aftermarket sont bien mous pour la plupart je trouve Confused...J'ai peur que les Megan Racing soient durs comme du bois, mème en 6/4
Astina37 Hors ligne
Integra type R / FR-V
27 - Eure France
Sujets : 23
05-04-2005, 13:07:25   -
Donc c est presque du 5/4 qu il faudrait si j ai bien compris...Tu confirmes Grumly?
Sujets : 101
05-04-2005, 13:30:59   -
Astina37, En 5/4 cela n'existe pas pour nos MR Sad
C'est 6/4.
Et le spring rate d'origine bah je l'ai jamais trouvé...
Je suppute du 3/2 mais en fait j'en sais fichtrement rien
sepi, en fait comem on m'a posé plusieurs fois la question j'ai déterré mon post:
https://www.japancar.fr/forum/viewtopic....mortisseur
Greg_P Hors ligne
Sujets : 42
05-04-2005, 13:47:39   -
Apparament, ca serait dans le service manual... je chercherai un peu si j'y pense ce soir.
Sujets : 101
05-04-2005, 18:03:37   -
dans celui de S13 oui....
Dans celui de S14 j'ai pas trouvé; on verra si j'ai une vue de taupe Wink
Greg_P Hors ligne
Sujets : 42
05-04-2005, 23:33:31   -
Non, ca n'y est pas a la fin des chapitre RA et FA... Pas de spring rate Sad
sepi Hors ligne
Sujets : 33
08-04-2005, 12:48:23   -
Ptit up, pour savoir si quelqu'un a enfin trouvé ce spring rate d'origine de la S14..
Greg_P Hors ligne
Sujets : 42
08-04-2005, 13:39:15   -
CA peut se faire avec un combine demonte. Je le ferai si j'y pense quand j'aurais mis mes apex...
sepi Hors ligne
Sujets : 33
08-04-2005, 14:33:55   -
Ok ça marche! D'ailleurs, les combinés apex ne devraient plus tarder maintenant...
Greg_P Hors ligne
Sujets : 42
08-04-2005, 15:34:24   -
Bren m'a dit avoir expedie les miens mardi.
Greg_P Hors ligne
Sujets : 42
08-04-2005, 17:53:50   -
Ben voila, GLS est passé cet aprem, mais ces abruti sont fermé le samedi... Du coup je les aurait pas avant lundi ... Evil Evil Evil Evil Evil Evil Evil Evil Evil Evil
Je suis deg. Sont pire qu'a la poste, GLS... Meme la poste est ouverte le samedi matin.
sepi Hors ligne
Sujets : 33
08-04-2005, 19:28:06   -
Gniark moi ils étaient a la Poste! J'adore mon facteur, il m'apporte tjrs des cadeaux! :P
[Image: coilovers1.jpg]
[Image: coilovers2.jpg]
Faut que je choppe chez Nissan les caoutchoucs entre la tete des coilovers et le chassis et le week prochain, on the road! j'ai trop hate de voir ce ke ça donne!
Greg_P Hors ligne
Sujets : 42
08-04-2005, 20:19:20   -
Ben je vais laisser ceux qui son la. Ils ont tout juste 50000 borne, ca devrait aller.
Sinon, c'est bizarre que pour toi ce soit la poste qui s'en soit chargé, alors que c'est GLS pour moi...
Franchement, pour une fois j'aurais preferé que ce soit la poste...
Sujets : 101
08-04-2005, 20:54:08   -
Greg_P a écrit :CA peut se faire avec un combine demonte. Je le ferai si j'y pense quand j'aurais mis mes apex...
C'est marqué dessus???
Car moi mes amortos d'origine sont dans mon garage donc je peux toujours regarder dessus Wink
Alors c'est marqué où?
Greg_P Hors ligne
Sujets : 42
08-04-2005, 21:08:14   -
Non, Mais pour le ressort, suffit de le charger d'une masse connue et de constater le raccourcissement du ressort...
sepi Hors ligne
Sujets : 33
09-04-2005, 14:53:18   -
Greg_P a écrit :Ben je vais laisser ceux qui son la. Ils ont tout juste 50000 borne, ca devrait aller.
Nop je m'suis gourré, c'était bien GLS, en fait je les ai fais livrés chez mes parents pour qu'il y ai quelqu'un pr les receptionner la journée Langue! ma mère m'avait dis ke ct la poste, mais c'est éffectivement GLS...oui, je me rappelle que pour mon collecteur inox, pareil je me suis tapé 30 bornes pour aller le chercher, j'en avais besoin urgeament, je les ai donc harcelé un samedi a 9h ds leur entrepot!
Sinon, moi ça revient au meme que si je les avaient eu lundi, je ne les monte pas ce week end (fait moche et g pas l'outillage, c'était pas prévu k'ils arrivaient hier)..
Greg_P Hors ligne
Sujets : 42
09-04-2005, 16:08:36   -
Oué, ben ce matin, j'ai fait la grasse mat...
  FAQ NISSAN : Preparation moteur 200sx s13 sebar 41 18 713 20-08-2008, 15:20:26
Dernier message: 80franck
  Spring rate ressorts sepi 57 3 106 26-07-2006, 22:06:15
Dernier message: sepi
  [FAQ Nissan] Nissan 200SX Goose 26 57 955 16-12-2005, 21:03:26
Dernier message: tibo
  What spring color ? ian© 11 779 18-01-2005, 21:06:07
Dernier message: SK_Flowne
