Instrument pour mesurer l'indice d octane
ZEeD Hors ligne
DSS CREW
Sujets : 19
16-04-2005, 23:44:50   -   Instrument pour mesurer l'indice d octane
voila ma question est simple
es kil exsiste un instrument portatif pour mesurer l indice d'octane réel de l essence ke je mets dans ma caisse ? Smile
The cool effect you don't expect !
brice Hors ligne
17-04-2005, 01:37:55   -
Oui ça existe, ça s'appelle un octanomètre (octanemeter/octanetester).
[Image: octanometr.jpg]
Citation : Octane tester is developed in Petroleum Chemisorption Institute of Siberian Branch of Russian Academy of Science. The fuel quality analyzer octanemeter is intended for evaluation of the type of gasoline, and determination its octane number. The octane meter also determines the cetane number of diesel fuel.
Equally good the octanemeter measures the parameters of the leaded and unleaded gasoline, as well as the gasoline with different additives. 10 seconds is the maximum time to detect the type of gasoline at the worst conditions (cold start). The entire process is automated - the operator only needs to fill the sensor with the gasoline, turn on the instrument, and write down the results from the display.
The octanemeter is simple in use, and does not require regular adjustments and special maintenance. The use of the octanemeter eliminates the human factor during the quality estimation of the oil products. It's recommended to use the instrument at petroleum storages, filling stations, customs houses, and for the check of the samples in gasoline production lines.
The measurement principle of the octane level is based on a comparative analysis between the parameters of the analyzed gasoline and the reference gasoline parameters stored in the microprocessor's memory.
The design of the instrument and the measurement algorithm provides a high-level noise immunity and, as a result, a stable measurement. During gasoline blending octane level can be controlled within the range from 40 to 120. There is an option to adjust the instrument for a nonstandard fuel, for example, natural (gaseous condensate) or virgin gasoline. An advanced user can perform such an adjustment without assistance of the instrument maker.
Pas facile facile à trouver si t'es un particulier, je pense que Conrad doit vendre ça en France, sinon essaye de voir avec quelqu'un qui bosse dans l'automobile, ils doivent avoir les bons catalogues.
« Aucun homme ne peut avoir un droit d'imposer une obligation non choisie, un devoir non récompensé ou une servitude involontaire à un autre homme. Le droit d'asservir n'existe pas. »
Ayn Rand - La Vertu d'Egoïsme
Fifi Hors ligne
Sujets : 34
17-04-2005, 16:21:35   -
A mon avis , c'est plus difficile que cela car quand tu connais la procédure de controle pour la course ... Je penses que si cet appareil était valable, la FIA s'en servirait pour controler et eviter de couteuses expertises dans des labos ( 800 euros)
Tu peux avoir une idée de ce qui est demandé et verifié en consultant l'annexe J actuelle, rubrique carburants, sur FIA.com
le Fifi de l'occident.
www.club-honda-classic.fr
SK_Flowne Hors ligne
18-04-2005, 09:45:23   -
Ouais enfin les tests labo de la FIA c'est surtout pour détecter la présence "d'additifs" destinés à doper les chevaux :roll:
Et puis arrêtez de toujours tout ramener aux procédure de test de la NASA, c'est lourd :roll:
[Image: sanstitre2.gif]
  [Pneus] Indice de Charge et de vitesse bobbymacferrin 20 11 270 07-03-2012, 11:06:27
Dernier message: TurboR
  [ENG] Indice d'Octane US/EURO/JAP, les veritées 1337CRX 3 2 593 28-10-2009, 13:34:59
Dernier message: roma
  Correspondance de taille de pneus et indice de charge ThE bArJo 1 4 167 02-09-2009, 14:59:27
Dernier message: boyou2
  Pression de SURalimentation celon RV et octane Iridium59 7 2 837 20-05-2009, 13:19:03
Dernier message: benR
  Indice d'octane et gestion programmable Lio 12 3 973 02-11-2007, 19:15:47
Dernier message: icedfluid
  Octane booster freeman R 13 4 035 17-06-2007, 15:46:14
Dernier message: Théo
  Comment mesurer la courbe de puissance avec un microphone! eyeball 5 2 071 31-07-2006, 18:10:02
Dernier message: HectorLeChat
  nos octane booster?!? Anonymous 10 3 426 30-03-2006, 20:10:45
Dernier message: brian flanagan's
  [pneus] indice UTQG IloveJapan2 3 1 521 23-10-2004, 20:10:02
Dernier message: mand_o
  Octane...CQFD grumly2000 5 2 375 22-10-2004, 12:02:37
Dernier message: [Nicco]
