lien interressant pour possesseur de 300ZX(tous les how to)
tibo Hors ligne
16-12-2005, 21:12:19   -   lien interressant pour possesseur de 300ZX(tous les how to)
bon voila je suis re tomber sur ses liens en parcourant le forum je les remet donc d'actualiter et en FAQ pour les ZXiens LOL LOL
c'est dans la langue de shakespeare mais il y a de jolie photos qui expliquent donc ca aide voila un petit apercu de se que vous pourer trouver ici
lien 1
Citation :Engine-Drivetrain, Troubleshooting/Maintenance:
Why does my Z hesitate sometimes?
Why does my Z hesitate at full throttle?
How do I clean my throttle bodies?
How do I tighten my throttle cable?
How do I keep my car from stalling at speed?
What causes safety boost?
How do I keep from constantly going into safety boost?
How do I perform the ECU diagnostic?
How do I perform ECU self diagnostics?
How do I perform the auto transmission diagnostic?
How do I find/fix a vibration?
How do I adjust my parking brake?
Am I having injector failure?
What can I do to pep up my higher mileage Z?
Why won't my car start when I turn the key?
My Z suddenly has 0psi of oil pressure!
How do I replace the oil pressure sender?
What's the 'gurgling' sound from the front fenders?
How do I replace the Idle Air Adjusting (IAA) unit?
How do I locate and repair fuel leaks?
How do I replace my shifter bushing?
How do I change my oil?
What's in the 60K maintenance routine?
How do I replace my stock airfilters or clean my K&N style?
How do I replace my fuel filter?
How do I replace my spark plugs?
How do I replace my timing belt?
How do I perform the HICAS self diagnostic?
How do I change my transmission and differential fluid?
What's the story with turning the brake rotors?
How do I rebuild my brake calipers?
My clutch is slipping, do I need a new one?
My transmission grinds from 5th to 4th, anything I can do?
My ignition coil connectors are all broken, I have to buy the whole expensive wiring harness?
What can be tested through the wiring harness?
What are the normal values displayed on the Techtom MDM-100?
How do I replace my PCV valves?
How do I remove my engine?
How do I replace my turbos?
How do I replace my EGR valve?
How do I check my compression?
How do I replace my clutch?
How do I replace my flywheel?
How do I replace my rear main seal?
How do I remove my transmission?
Does my fan in front of the radiator work?
How do I check my oxygen sensors?
How do I fix my center console clock?
Engine-Drivetrain, Modifying:
Should I get blow-off valves or not? Do they really help?
How do I install blow-off valves?
Could someone explain boost jets to me?
How do I set the boost with boost jets or welding tips?
What is a modified torque converter, and do I want/need one?
How do I paint my brake calipers?
How do I install a K&N style intake?
How do I install a twin POP intake?
How do I tweak my timing?
How do I replace my brake rotors?
How do I install NA headers?
How do I do an ECU swap & boost jet install?
How do I gut my pre-cats?
How do I install an underdrive pulley?
How do I change my brake pads?
How do I install stainless steel brake lines?
Is going with a lightened flywheel worth it?
What's involved in a properly upgraded turbo?
How can I remote mount my Blitz turbo timer or other electronics?
How do I install a traction control?
How do I swap differentials?
How do I install aftermarket intercoolers?
How do I install a HKS Twin Power Ignition Amplifier?
What are the ARP part numbers?
Engine-Drivetrain, Misc:
How do I remove the shift knob?
What is the lug pattern size?
How do I replace a broken wheel stud?
Does my automatic Twin Turbo really have 20 horsepower less at the flywheel?
How do I read the engine timing marks correctly?
What size tires can I run?
Body-Electrical, Troubleshooting/Maintenance:
My hood squeaks when I go over bumps, how do I stop this?
What's that buzzing sound coming from the cabin lights?
How do I bleed the brakes?
How do I get my Z really clean?
How do I remove swirl marks in my paint?
How do I run the diagnostics on my auto climate control?
My Cruise Control doesn't work. What do I check?
Body-Electrical, Modifying:
BOSE?
How do I replace my BOSE system?
How can I put black-outs on my taillights so they look different?
What is the correct offset for aftermarket rims?
How do I rewire my fog lights?
How do I instal a shift light?
How do I make my foglights brighter?
How do I install air guides for rotor cooling?
How do I tweak my stock suspension for Autocross?
How do I install a pillar mounted boost gauge?
How do I replace my front tension rods or install adjustable ones?
How do I install adjustable upper links (A-arms)?
How do I make the 300ZX on the rear panel glow?
Body-Electrical, Misc:
How do I get my dashboard off?
How do I remove my front facia to replace it?
How do remove my front fenders?
Misc:
Can I convert my NA to a TT?
What color is my Z?
More on colors codes & serial numbers
Any stats on what models/colors/etc were produced?
What are the differences between model years?
Where can I look for Zs for sale on the internet?
What should I look for when purchasing a used Z?
What are the best shift points?
What is the best way to import a Z from Canada?
What magazines was the Z in?
How do I read the NGK spark plug codes?
et voila un deuxieme liens
lien 2
de nombreux passages au banc de 300ZX dans differente configuration d'evolution moteur
Citation :Dyno Charts
Air Guides for Rotor Cooling Installation
Timing Tweak
Rotor Replacement
NA Header Install
ECU Swap & Boost Jet Install
Pre-Cat Gutting
Colors Codes & Serial Numbers
ECU Diagnostics
Autocross Suspension Tweak
Underdrive Pulley Install
Brake Pad Install
Stainless Steel Brake Line Install & Brake Bleeding Procedure
Boost Gauge Install
Shifter Bushing Replacement
Oil Change
Tension Rod Install/Replacement
60K Maintenance
Air Filter Replacement/Cleaning
Fuel Filter Replacement
Spark Plug Replacement
Timing Belt Replacement
HICAS Diagnostic
Twin POP Install
Cat-Back Exhaust Install
Transmission and Differential Fluid Change
PCV Valve Replacement
Engine Removal
Turbo Replacement
EGR Valve Replacement
Auto Climate Control Diagnostics
Anti-Sway Bar Install
Clutch and Flywheel Replacement
Intercooler Installation
Door Hinge Alignment
Door Handle/Lock Repair
Ground Net Installation
Split Cargo Cover Repair
voila je peu pa faire beaucoup plus pour vous apres reste plus qu'a lire Wink
[table][Image: sanstitre16iy.jpg][|]
  • filtre K&N+admission dynamic
  • bougie iridium
  • cat-back sur mesure en 2.25”
  • sortie 100mm type HKS
  • jante 15” TD drifz
  • glastint
  • collecteur 4/2/1 OBX
  • ressort court –40mm[/list:u] [|][Image: sanstitre0cy.jpg][/table]
    en attente: faisceau allumage ngk premium, boite de nx gti, teintage répétiteurs en noir, feu arriere de phase 3
Bubuche Hors ligne
Sujets : 48
16-12-2005, 23:18:27   -
excellent, je les avait déjà mais merci pour les autres Wink
Si certains ont besoin de traduction, je peux peut être les aider
twin-turbo Hors ligne
Sujets : 43
16-12-2005, 23:44:53   -
j'ai... 8)
Je vise le meilleur... J'envisage le pire... Je prends ce qui viens !!!
[Image: sign.jpg]
Sujets : 43
16-12-2005, 23:45:42   -
tien , voila ma participation...
http://www.300zx.org.uk/tech_00.htm
Wink
[Image: sign.jpg]
tibo Hors ligne
17-12-2005, 00:01:53   -
twin-turbo, Yes nikel ma poule et avec tout ca il a fallut que je te fasse le diag ???
hiiiiii branleur LOLLOL
  • bougie iridium
  • glastint
Sujets : 43
17-12-2005, 00:02:44   -
tibo a écrit :twin-turbo, Yes nikel ma poule et avec tout ca il a fallut que je te fasse le diag ???
normal... c ca la classe... 8)
[Image: sign.jpg]
  [200SXs13] Avis aux possesseur de ligne SSautochrome et autr cutzilla13 17 3 571 13-03-2007, 21:38:38
Dernier message: streetbike
  Recherche lien gunt 5 1 580 17-11-2006, 18:00:56
Dernier message: boyou2
  Lien sur intercoolers photos + dimensions lyckaon 4 1 515 16-11-2006, 15:17:09
Dernier message: twin-turbo
  Besoin d'aide des possesseur de TOP MOUNT!!! 09s14 11 2 576 17-08-2006, 15:47:24
Dernier message: fiftyone51
  Rassemblement NISSAN voir lien tony-s14 10 2 847 01-08-2006, 21:01:45
Dernier message: tony-s14
  lien pour des pieces nissan silviaS12 7 2 162 16-01-2006, 15:07:46
  nouveau lien pour des turbos nissan200sxs13 1 799 19-11-2005, 02:00:09
  cherche lien joe200sx 11 1 163 27-10-2005, 17:44:07
Dernier message: Goose
  question au possesseur d'un S13 CATALYSE tioubm 3 734 15-09-2005, 09:09:07
Dernier message: tioubm
  avis au possesseur d'avcr KEMOUTE 02 16 1 507 04-09-2005, 13:21:08
Dernier message: naru
