[Supra MKIV] 1995 blackbird single t61 bv6 uk spec
ludocrx52 Hors ligne
S13 RB26
52 - Haute-Marne France
Sujets : 35
31-08-2013, 22:39:02   -   [Supra MKIV] 1995 blackbird single t61 bv6 uk spec
Salut les amis, ça y es le rêve est réalisé, la belle est arrivée ce matin Smile Smile Smile
Un grand merci a Omar et Guillaume de la société www.gocarz.eu qui se sont occupés de l import avec un sérieux exemplaire Wink
Pour la liste des specs, la voici (désolé en anglais)
D autres photos de meilleure qualité viendront par la suite Wink
New parts in the last 10k include:
front discs with hawk pads front and rear
tein super street coilovers
both rear wheel bearings and hubs replaced
complete overhaul of rear diff including LSD,bearings and seals
engine mounts
clutch replaced both rear seals were changed on the gearbox along with the bushes.
steering rack replaced
Front and rear facelift lights
Facelift Indicators
OEM carpet
Facelift leather roof lining
TRD carbon spoiler
Full respray
New tyres
New Battery
New Wipers
The list goes on
Spec as follows:
Engine spec:
HKS forged pistons
HKS metal head gasket
ARP studs
HKS 256/264 cams
HKS exhaust adjustable cam pulley
5 angle valve modification to head
Turbocharger & Induction:
SP T61 turbo
S/S 4" turbo induction pipe
S/S modified XS power tubular manifold
Custom 2" screemer pipe
HKS style 50mm external wastegate
4" AEM filter
Custom 3" alloy intercooler pipe work from turbo to throttle body, using samco hose couplers
custom intercooler delta fin (same as apexi)
S/S goodridge oil feed/return hoses
Custom turbo heat shield
HKS SSQV 2
Custom Oil catch tank
Fuel, tuning & Ecu:
HKS VPC
Apexi safc 2
HKS FCD
HKS EVC 4
HKS turbo timer 2
HKS twin ignition ( DLI )
Racelogic traction control
Exhaust:
S/S 3" custom downpipe Vband heat wrapped
HKS 3" 2nd decat pipe
HKS silent hi power cat back
Cooling:
Silicon lower rad pipe
S/S upper rad pipe
Custom alloy radiator
Custom S/S rad cover plate
Toyota long life coolant
Drivetrain:
South bend DXD feramic clutch
Solid gear shift bushes
rear diff over hauled including LSD
Suspension,Wheels,Tires and Brakes:
Tein superstreet coilovers
18" BBS RS-GT Split rim alloys, 9" front & 10" rear refurbed 500 miles ago
Uk calipers painted black
Powerslot discs
S/S Goodridge braided hoses
Hawk brake pads front and rear
HKS front strut brace
Cusco rear strut brace
front toyo proxes T1R 225/40/18 nearly new
rear toyo R888 285/35/18 nearly new
Interior and ICE:
JVC touch screen head unit
Alpine 10" sub and amp
MVP alloy dash rings
Dash sprayed gloss black
Greedy alloy gear knob
Black oem carpet like new
Black leather facelift roof lining
Razo pedal set including foot rest
Alloy handbrake handle
Exterior:
Brand new Facelift front headlamps
Brand new Facelift rear lights
Brand new Facelift front indicators
OEM HID headlights
LED Side lights
Clear side repeaters
Full carbon TRD spoiler sides painted black leaving end caps and blade carbon
J spec front bumper without head lamp washers
Active spoiler fixed down
Bonnet lifters
Lexus spray washer jets
Other:
Stock TRAC removed and smoothed throttle body
Stock EGR removed
Custom PAS Cooler
Security:
Toad A606i Cat 1 alarm immobiliser
Performance:
Producing 538 rwhp at 1.2 bar and 471ft/lb of torque
[Image: vhxr.jpg]
[Image: iaaf.jpg]
[Image: v8ig.jpg]
[Image: u308.jpg]
[Image: 7ps3.jpg]
[Image: v33p.jpg]
GENTLEMAN DRIVER Hors ligne
GSXR 1340 HAYABUSA
26 - Drôme France
31-08-2013, 23:19:58   -   RE: [Supra MKIV] 1995 blackbird single t61 bv6 uk spec
Félicitations!! Elle est très jolie Wink
Tant que t'as pas vu Dieu dans le virage, c'est que c'est pas le moment de freiner.
« Nous courrons tant qu'il restera de l'essence. Nous courrons tant que nous aurons des idées, de l'argent, du courage, des mains, des bras, de l'air à respirer et du sang coulant dans nos veines. » Enzo Ferrari
ZacKisBacK_Fr Hors ligne
SilGTO 570sx
01 - Ain France
31-08-2013, 23:44:04   -   RE: [Supra MKIV] 1995 blackbird single t61 bv6 uk spec
Jolie!! Elle doit commencer à bouger à ce niveau de puissance,tu vas rigoler!
[Image: 599786DSC2851.jpg]
Cat's kills / Cat skills
Mugen34 Hors ligne
Supra mk3 Turbo Targa
01-09-2013, 02:04:08   -   RE: [Supra MKIV] 1995 blackbird single t61 bv6 uk spec
tres jolie!
hardlover Hors ligne
Nioule
Réputation : 40
01-09-2013, 02:16:46   -   RE: [Supra MKIV] 1995 blackbird single t61 bv6 uk spec
Belle supra, j'aime bien son coté sobre mais puissante.
(09-12-2014, 11:28:11)madmax616 a écrit : Open diff:
La voiture ne partait pas facilement, a moins d'être déjà bien lancé tout ca pour faire un mini travers qui ne dure pas. On ne parlera pas du départ arrêté ou une seule roue danse la Javanaise alors que l'autre fait une pause syndicale. Sac
mc-ouille30 Hors ligne
01-09-2013, 05:13:12   -   RE: [Supra MKIV] 1995 blackbird single t61 bv6 uk spec
ces de la pornographie ta supra :O elle est sublime , un reve <3
Eylir Hors ligne
WRX STI 8
01-09-2013, 12:21:37   -   RE: [Supra MKIV] 1995 blackbird single t61 bv6 uk spec
Belle bete, vu que c'est une UK Spec j'imagine que c'est moins dur à homologuer que si ça avais été une Jap avec la même prepa!
S13 RB26
Sujets : 35
01-09-2013, 12:34:34   -   RE: [Supra MKIV] 1995 blackbird single t61 bv6 uk spec
Oui Wink
Merci les mecs Smile
jimmy07 Hors ligne
Réputation : 10
01-09-2013, 12:52:18   -   RE: [Supra MKIV] 1995 blackbird single t61 bv6 uk spec
Tres bon choix!
Une supra noir avec boite mecanique en mono turbo
Ca doit envoyer!
(01-09-2013, 12:21:37)Eylir a écrit : Belle bete, vu que c'est une UK Spec j'imagine que c'est moins dur à homologuer que si ça avais été une Jap avec la même prepa!
Modele sorti en france donc tres rapide a homologuer et peu honereux
bob44 Hors ligne
Colt GTI CA5A
44 - Loire-Atlantique France
01-09-2013, 18:20:17   -   RE: [Supra MKIV] 1995 blackbird single t61 bv6 uk spec
superbe supra !!! belle acquisition
Mitsubishi Colt glxi: boite de GTI
                            AAC Jasma 282°
                            ITB sr20(a venir)
BARJOZOKU  Cool
Revo Hors ligne
Impreza GT Turbo 99
41 - Loir-et-Cher France
01-09-2013, 19:31:37   -   RE: [Supra MKIV] 1995 blackbird single t61 bv6 uk spec
Jolie ! Michto la taille du silencieux, t'as bien de quoi faire griller 20 saucisses en même temps là Sac
C'est vrai que ça doit bien se déplacer comme caisse Big Grin
S13 RB26
Sujets : 35
02-09-2013, 11:36:11   -   RE: [Supra MKIV] 1995 blackbird single t61 bv6 uk spec
Merci Wink
S13 RB26
Sujets : 35
14-09-2013, 14:21:00   -   RE: [Supra MKIV] 1995 blackbird single t61 bv6 uk spec
nouvelles photos Wink
En mode détuningage Wink nouveaux caoutchouc de pédales a la place du kit pédalier Koundélitch :rofl: :rofl: :rofl:
Les 2 caoutchoucs 8.44 euros HT chez Toyota pour infos, ce sont les 2 mêmes Wink
Quelques photos en varc :devil: :devil: :devil:
[Image: xt5k.jpg]
[Image: iayd.jpg]
[Image: o0y0.jpg]
[Image: 3mdj.jpg]
[Image: kcyb.jpg]
[Image: qufy.jpg]
[Image: nj61.jpg]
cotoCRX Hors ligne
toyota mr2
26 - Drôme France
14-09-2013, 15:11:41   -   RE: [Supra MKIV] 1995 blackbird single t61 bv6 uk spec
Superbe supra.
Tiens les caoutchouc de pédales ça m’intéresse ça, j'ai des pédales tuning sur ma Lexus Sad
-Lexus IS200 dailydrive
-MR2 turbo goodwood green à vendre
-MR2 turbo fast road and track car
[Image: 1304080225078586111062210.jpg]
S13 RB26
Sujets : 35
16-09-2013, 01:42:54   -   RE: [Supra MKIV] 1995 blackbird single t61 bv6 uk spec
oui c est beaucoup plus joli l origine Wink
axe79 Hors ligne
Mitsubishi EVO VIII
79 - Deux-Sèvres France
21-09-2013, 14:25:41   -   RE: [Supra MKIV] 1995 blackbird single t61 bv6 uk spec
C'est Zak sont prénom pas Omar ^^
Content que tu sois satisfait de la prestation de l'équipe que je t'ai conseillé et que personne connait Smile
powered by CT9a
jack estripador Hors ligne
Réputation : 6
21-09-2013, 15:02:36   -   RE: [Supra MKIV] 1995 blackbird single t61 bv6 uk spec
YepYepYep tres belle
[Image: 1922045_520099374767874_1450621632_n_zps268b5fcd.jpg]
S13 RB26
Sujets : 35
22-09-2013, 15:51:44   -   RE: [Supra MKIV] 1995 blackbird single t61 bv6 uk spec
(21-09-2013, 14:25:41)axe79 a écrit : C'est Zak sont prénom pas Omar ^^
oups lol
oui en effet très content Wink
Arthman78 Hors ligne
Honda Prelude 3G 4WS
78 - Yvelines France
22-09-2013, 15:56:00   -   RE: [Supra MKIV] 1995 blackbird single t61 bv6 uk spec
Très belle voiture!!! Elle est dans un super état on dirais Smile
pierrick087 Hors ligne
Honda integra type R
03 - Allier France
22-09-2013, 18:48:44   -   RE: [Supra MKIV] 1995 blackbird single t61 bv6 uk spec
Elle en impose !!
Et effectivement elle à l air vraiment propre !!
S13 RB26
Sujets : 35
23-09-2013, 23:10:04   -   RE: [Supra MKIV] 1995 blackbird single t61 bv6 uk spec
Oui très propre mais à part le siège conducteur usé et le support inférieur de radiateur rouillé (maladie supra mk4)
S13 RB26
Sujets : 35
10-10-2013, 21:18:13   -   RE: [Supra MKIV] 1995 blackbird single t61 bv6 uk spec
Quelques petites news, une durite refroidissement changée, des nouveaux caches moyeux BBS originaux.
A suivre changement filtre a essence, vidanges boite et pont (pas encore eu le temps Oops! ), continuation homologation, AFR et EGT Wink
Quelques photos en vrac dont un passage au banc de 2008, un passage chez Toyota, délires et rassos sympa Wink
[Image: zay3.jpg]
[Image: i0p0.jpg]
[Image: wa38.jpg]
[Image: ocgu.jpg]
[Image: hn8a.jpg]
[Image: qggw.jpg]
[Image: kwo7.jpg]
[Image: ocev.jpg]
[Image: 1s2x.jpg]
Uploaded with ImageShack.us
A suivre ... Smile Wink Wink
10-10-2013, 21:27:49   -   RE: [Supra MKIV] 1995 blackbird single t61 bv6 uk spec
Tient la lotus blanche qui est sur les précédentes photos je crois la connaitre Big Grin
cotoCRX Hors ligne
toyota mr2
26 - Drôme France
11-10-2013, 12:47:03   -   RE: [Supra MKIV] 1995 blackbird single t61 bv6 uk spec
La montre !!!!
S13 RB26
Sujets : 35
13-10-2013, 18:56:35   -   RE: [Supra MKIV] 1995 blackbird single t61 bv6 uk spec
(10-10-2013, 21:27:49)Arthman78 a écrit : Tient la lotus blanche qui est sur les précédentes photos je crois la connaitre Big Grin
ah ?
Disco*** Hors ligne
HONDA Civic GT '87 (AH53)
93 - Seine-Saint-Denis France
14-10-2013, 14:31:43   -   RE: [Supra MKIV] 1995 blackbird single t61 bv6 uk spec
Sexy!
Kilométrage?
DEUM DI DEUM!
S13 RB26
Sujets : 35
15-10-2013, 01:22:08   -   RE: [Supra MKIV] 1995 blackbird single t61 bv6 uk spec
la caisse presque 200 000 kms et le moteur moins de 100 000
S13 RB26
Sujets : 35
24-01-2014, 14:41:45   -   RE: [Supra MKIV] 1995 blackbird single t61 bv6 uk spec
Quelques petites news, ça n avance pas très vite, la maison en priorité Wink
Photos plus ou moins récentes
En mode craquage:
[Image: ky1f.jpg]
Mode maniaco dépressif Wink
[Image: od6k.jpg]
Afr aem reçu Wink
[Image: ofqu.jpg]
Certificat de conformité partiel Toyota reçu et petite miniature trouvée par hasard sur la toile Wink
[Image: ezz2.jpg]
Clin d œil
[Image: cy6t.jpg]
Révision en cours, distri complète + pompe a eau, toutes vidanges, filtres ...
[Image: n6or.jpg]
Photos Seb Wink
[Image: tq9f.jpg]
[Image: glf7.jpg]
[Image: hlqx.jpg]
Noir c est noir ...
[Image: 9n84.jpg]
Un peut de déco Wink
[Image: khwc.jpg]
fefe hyundai Hors ligne
i30 N Performance Pack
Sujets : 558
26-01-2014, 13:27:03   -   RE: [Supra MKIV] 1995 blackbird single t61 bv6 uk spec
C'est beau ca brille Cool
Hyundai Coupe RD2 -> Mazda MX5 NBFL -> Subaru Impreza 2.0D Sport -> Smart Forfour Brabus 4G15T -> Lexus IS200 pack Luxe -> Mazda 3 MPS 1G -> Toyota Aygo VVTI pack Sport -> Hyundai i30 N Performance Pack ICI !!!
S13 RB26
Sujets : 35
30-01-2014, 00:54:01   -   RE: [Supra MKIV] 1995 blackbird single t61 bv6 uk spec
merci Wink
  [EG9] Honda Civic 1.6 VTi 1995 Pallfa 9 562 28-03-2024, 01:05:27
Dernier message: Pallfa
  [Toyota] Supra Mk4 1995 - IzateuSupra ? Une belle merguez bien cuite svp DVPconcept 41 4 105 24-08-2023, 13:55:48
Dernier message: DVPconcept
  [Nissan Silvia S15 Spec-R] Objectif OEM + Slide_K 20 1 617 31-05-2023, 16:49:45
Dernier message: Snowmonkey
  [JZA80] Supra RZ single turbo, BV6 ON [Nicco] 510 74 041 21-01-2023, 18:51:34
Dernier message: [Nicco]
  [RX7 FC3S TURBO II UK SPEC] ryosuke 79 7 304 12-09-2022, 14:02:20
Dernier message: SoichiroYann
  [P10] 1995, SR20DE 125ch BVA S0LlDSNAKE 10 663 27-09-2021, 21:47:40
Dernier message: S0LlDSNAKE
  [Nissan ϟilvia S15 Spec R] Roadtrip 2018: carnet de bord p. 11 FastFWD 335 48 606 21-04-2021, 13:43:32
Dernier message: boyou2
  [R33 GTS-T spec 2] alexr33gts-t 1 685 23-12-2020, 12:55:13
Dernier message: fefe hyundai
  [RX-7 FD3S] Single Turbo | Du nouveau ^^ CloudRX 145 14 930 03-11-2020, 11:23:58
Dernier message: Jibe
  [Supra] - Toyota Supra MK4 - White Lady Nicolay45 368 60 953 25-06-2020, 00:36:21
Dernier message: BobsleiiG
