fefe hyundai
i30 N Performance Pack
34 - Hérault France Messages : 14 189
Sujets : 558
27-02-2017, 12:45:04 - RE: [F1]Saison 2017 - Post Officiel
LE DJACK
Papi de JPC
Civic MB 6
03 - Allier France Messages : 533
Sujets : 40
27-02-2017, 12:45:39 - RE: [F1]Saison 2017 - Post Officiel
La réglementation FIA est claire sur le sujet :
" 3.7.3 Forward of a point lying 450mm ahead of the front wheel centre line and less than 250mm
from the car centre line and less than 125mm above the reference plane, only one single
section may be contained within any longitudinal vertical cross section parallel to the car
centre line.
Furthermore, with the exception of local changes of section where the bodywork defined in
Article 3.7.2 attaches to this section, the profile, incidence and position of this section must
conform to Drawing 7. This section may not contain any closed channel the effect of which is
to duct air directly or indirectly to or from the external air stream for any purpose other than
data acquisition. "
" 3.7.5 Only a single section, which must be open, may be contained within any longitudinal vertical
cross section taken parallel to the car centre line forward of a point 150mm ahead of the front
wheel centre line, less than 250mm from the car centre line and more than 125mm above the
reference plane.
Any cameras or camera housings approved by the FIA (and the parts used to attach these to
the bodywork up to a width of 15mm in the direction perpendicular to the car centre line), in
addition to a single inlet aperture for the purpose of driver cooling, such aperture having a
maximum projected surface area of 1500mm2 and being situated forward of the section
referred to in Article 15.4.3(a), will be exempt from the above.
Il ne faut pas avoir peur des chevaux sous le capot, mais de l'âne derrière le volant
nourse
Corolla TS
13 - Bouches-du-Rhône France Messages : 816
27-02-2017, 13:45:09 - RE: [F1]Saison 2017 - Post Officiel
ptain, pour l'instant vettel en pneu mediums a un meilleur chrono que Bottas en tendres
elle a l'air violente cette nouvelle ferrari
"les chats, c'est vraiment des branleurs"
(Modification du message : 27-02-2017, 13:45:58 par nourse.)
DC one
LOTUS Elise S3 SC
35 - Ille-et-Vilaine France Messages : 2 711
Sujets : 82
28-02-2017, 14:01:32 - RE: [F1]Saison 2017 - Post Officiel
Stroll, pour être honnête, je n'en attend pas forcément grand chose ...
Après Alonso hier, encore un changement du groupe motopropulseur aujourd'hui pour Vandoorne, décidément, ça va de + en + mal chez Honda !
Pendant ce temps là, Hamilton fait record du tour sur record du tour ... alors oui, ce ne sont que des essais de pré saison mais de toute évidence, la Mercedes est encore bien née (et sans l'aileron de requin aujourd'hui ...)
Confirmation pour Mercedes, fin de la séance, Hamilton colle 2s au 2nd (Raikkonen) et a en moyenne fait 2 fois plus de tours que les autres ...
Pour Strool, cette 1ère journée vient un peu + appuyer ce que je disais: il est sorti au bout de 12 tours ce matin et la voiture n'est pas réparable aujourd'hui, donc journée terminée pour Williams ...
Bottas prend le relais d'Hamilton cet aprem.
(Modification du message : 28-02-2017, 15:23:00 par DC one.)
niavlysj
'96 EJ9
- France Messages : 3 537
01-03-2017, 11:06:03 - RE: [F1]Saison 2017 - Post Officiel
[mode = mauvaise langue]
(01-03-2017, 10:30:50)DC one a écrit : A suivre entre autre aujourd'hui [...] Alonso de retour dans la Mc Laren
Alonso de retour dans la McLaren, ou la McLaren de retour (tout court)
[/mode]
j'aime beaucoup cette équipe, mais au bout d'un moment, faudra qu'ils revoient leur façon de travailler en amont, car là y a un truc qui colle pas. Dommage, car en dehors de ça, peut être que le bloc a du potentiel, mais impossible à voir encore.
fefe hyundai
Sujets : 558
01-03-2017, 12:13:07 - RE: [F1]Saison 2017 - Post Officiel
