correspondance ecu CA18DET
tibo Hors ligne
23-06-2005, 12:52:08   -   correspondance ecu CA18DET
ECU PINS - Description of use
1 - Coil pack 1 output (via power transistor Unit)
2 - Coil pack 2 output (via power transistor Unit)
3 - Coil pack 3 output (via power transistor Unit)
5 - Boost pressure control solenoid (domestic Japanese cars only, not Euro models)
6 - Air conditioner relay
7 - Tacho drive output to tachometer
8 - Variable intake butterfly control solenoid (domestic Japanese cars only, not Euro models)
10 - Ground
11 - Coil pack 4 output (via power transistor Unit)
16 - ECCS system relay (earth = on)
17 - Injector pulse duty output (to trip computer for fuel usage measurement)
18 - Fuel pump relay (earth = on)
20 - Ground
23 - Knock sensor input
26 - Air flow meter pin B (ground ?)
27 - Air flow meter pin A
28 - Coolant temp sensor input
29 - Oxygen sensor input (unleaded catalyzer model only)
30 - Sensor earth
32 - Check lamp output to check connector (green)
33 - Check lamp output to check connector (red)
37 - Air flow meter pin D (non cat models ? )
38 - Throttle Position Sensor potentiometer (wiper)
41 - Crank angle sensor 180 deg input
42 - Crank angle sensor 1 deg input
43 - start signal (cranking) from ignition switch
44 - Neutral(manual) / park(auto) gearbox switch signal
45 - Ignition On switch signal
46 - Air conditioner thermostat input (ECU controls AC activation)
47 - To check connector ?????
48 - TPS potentiometer battery output (5 volt?)
49 - Battery from ECCS relay
50 - Ground
51 - Crank angle sensor 180 deg input
52 - Crank angle sensor 1 deg input
53 - Speed sensor input via the speedometer
54 - TPS switch (throttle idle position)
55 - Ambient air temp sensor input (sensor is in front of radiator)
56 - ?????
57 - TPS switch (full throttle position)Auto trans? (kick down switch)
58 - battery, unswitched
59 - battery from ECCS relay
60 - Ground
101 - Injector No 1 drive output
103 - Injector No 3 drive output
106 - AAC (aux/idle air control) valve output
107 - Injector drive ground
108 - Injector drive ground
109 - Battery from ECCS relay
110 - Injector No 2 drive output
111 - ? CA18DET A/T ? or pressure reg control valve?
112 - Injector No 4 drive output
115 - Heater output for O2 sensor (unleaded catalyzer model only)
116 - Injector drive ground
opla trouver sur www.npclub.com Wink
Jibe Hors ligne
NISSAN BNR32
Sujets : 122
23-06-2005, 13:13:19   -
Merki! Wink
S13RB26 300RWkW=>FD3S 250RWkW=>FDstreetport 270RWkW=>BNR32 240AWkW
RLS30-000007 07/1973 L26 work in progress
  Correspondance Reference Butée CA18DET boyou2 7 5 712 18-08-2015, 14:16:39
Dernier message: boyou2
  problème ECU s13 ca18det fly-gtr 12 4 829 26-09-2009, 18:40:04
  info ECU CA18DET (niveau expert de la prog requis... :lol:) fiftyone51 87 11 708 10-03-2009, 11:10:13
Dernier message: Kim
  correspondance pieces moteur Z32 / S13 skoh 7 1 623 16-06-2006, 12:57:05
Dernier message: Jack-of-all-Trades
  correspondance amortos? sebar 2 804 19-12-2005, 09:22:41
Dernier message: stef78
  Dump de l'ECU impossible = ECU modifié? grumly2000 4 1 396 16-11-2005, 16:40:42
Dernier message: grumly2000
  correspondance ecu SR20DET tibo 5 2 190 25-09-2005, 17:24:13
Dernier message: Biohazard200sx
  Wiring Ecu Ca18det bambby 6 2 045 27-05-2005, 20:41:08
Dernier message: Guest
  correspondance plaquettes S13 et question disque fab14 4 1 155 14-02-2005, 21:52:49
Dernier message: fab14
  correspondance sieges 300zx 2 places/4places tyler 3 1 231 29-09-2004, 18:03:13
Dernier message: tyler
