tonyjee
Papa pressé ....
Civic FN1 / Yaris 2NZ
- France Messages : 15 082
Sujets : 115
17-09-2014, 23:31:46 - RE: Vidéos sympathiques et bien faites
ouep tu m'étonne
(Modification du message : 17-09-2014, 23:32:06 par tonyjee.)
Vass91
19-09-2014, 14:00:39 - RE: Vidéos sympathiques et bien faites
Bienvenue chez les bourrains
DAV4WS
Mineur de corde
24-09-2014, 13:23:10 - RE: Vidéos sympathiques et bien faites
sympa la vidéo du HEm on aperçois ma vielle prélude a 5'45
[Vidéo: https://www.youtube.com/watch?feature=pl...a5iCxiOonk]
Project-G’s "Red Devil" started as a 1992 1.6 Miata. Joe and Steve (owners of Project-G LA) tore the car down to almost a shell and started building it. It may be hard to believe, but the guys were able to put this car together with spare parts they had in the shop. The idea behind the build was to show what a street car with stock ECU could do, and showcase the capabilities of the standard Kraftwerks Supercharger system.
They started by eliminating the original 1.6 liter, and swapping in 1.8 liter engine/wire-harness with a 6-speed transmission swap and torsen rear end from a Mazdaspeed Turbo Miata. To get the car down the road a bit faster a Kraftwerks Supercharger Kit, Skunk2 Pro-Series Throttle Body, Koyo radiator, Racing Beat header and RS-R exhaust was installed. Although the standard intercooler works just fine, Project-G upgraded the intercooler to a larger unit, filling up the Miata's grill completely. Joe stated, "we are also running our new intercooler friendly air guide which we have driven for over 200 miles in 100+ degree heat up the grapevine for WekFest San Jose just last week, the car did phenomenal!"
Which leads us to their opinions on the Kraftwerks Supercharger kit. Project-G said, "the Kraftwerks system has taken a fun, nimble, and well behaved car and pushed it to the next level. It is still reliable and street friendly, but with the added power it instantly transforms into a wicked street machine. The installation of the Kraftwerks system is straight forward and surprisingly easy when compared to other forms of forced induction. Easily installed over a weekend at a leisure pace, but can be installed and on the road in an afternoon if you are familiar with the kit. Everything fit right out of the box with no modifications needed or anything else to be purchased, it even comes with injectors and a fuel pump. Colder plugs (one step lower) are recommended and a fresh fuel filter is a good idea while you are at it. On a side note, the kit can be removed easily in 2 hours or less if there were ever a need to do so."
It didn't stop there, they kept going with a pearl grey rollbar and matching valve cover. Then this little street beast was finished up with Hayashi taillights from Japan, APR carbon mirrors and a R-Package front lip, along with a dash/interior conversion from a 2005 Miata. Joe told us, "we wanted to go a different route and did it two-tone with light grey and black to match the brushed Nardi steering wheel. To achieve the vehicles low/wide stance a set of Skunk2's newest Pro-ST adjustable Coilovers and a set of Work Meister S1's in an aggressive 15x9.5, 0-offset were called upon for the job.
Project-G offers a variety of their own products that are featured on the build, including the infamous side G-Fusers on the outside, G-String bikini top (in light grey to match). In the interior you'll find inside G-Vents(vented wing windows) and their leather shift boot also to match the Nardi wheel. To clean up the engine bay they grabbed a few things off the shelf as well! You'll find the entire Project-G Precision Series Engine Dress-Up Kit(oil cap, plug cover & dip stick handle).
(Modification du message : 24-09-2014, 13:27:34 par DAV4WS.)
DAV4WS
Mineur de corde
24-09-2014, 13:29:23 - RE: Vidéos sympathiques et bien faites
ro la vidéo du monster !!j'en veux un!!!
DAV4WS
Mineur de corde
26-09-2014, 11:16:42 - RE: Vidéos sympathiques et bien faites
(Modification du message : 26-09-2014, 12:38:50 par DAV4WS.)
- France Messages : 29 162
26-09-2014, 16:14:46 - RE: Vidéos sympathiques et bien faites
deja mise la video sur le bloc en stop-motion.
Niko78
29-09-2014, 14:15:49 - RE: Vidéos sympathiques et bien faites
une petite nsx bien sympa
[Vidéo: http://vimeo.com/63920788]
(Modification du message : 30-09-2014, 19:35:28 par Niko78.)
29-09-2014, 14:39:29 - RE: Vidéos sympathiques et bien faites
messieurs, merci de mettre les balises pour integrer directement les videos.
Concernant la cressida, deja mise quelques pages avant.
DAV4WS
Mineur de corde
29-09-2014, 14:50:46 - RE: Vidéos sympathiques et bien faites
(Modification du message : 29-09-2014, 14:51:22 par DAV4WS.)
DAV4WS
Mineur de corde
30-09-2014, 15:21:42 - RE: Vidéos sympathiques et bien faites
(Modification du message : 30-09-2014, 15:25:18 par DAV4WS.)
DAV4WS
Mineur de corde
01-10-2014, 08:51:26 - RE: Vidéos sympathiques et bien faites
tonyjee
Papa pressé ....
Sujets : 115
01-10-2014, 10:30:08 - RE: Vidéos sympathiques et bien faites
Popopoooooooo !!! jolie sélection ... ... Rooooh la stingray
DAV4WS
Mineur de corde
01-10-2014, 10:54:43 - RE: Vidéos sympathiques et bien faites
héhé , me doutais que t'allais poster faillit te dédicacer la vidéo de la ford !
tonyjee
Papa pressé ....
Sujets : 115
01-10-2014, 10:59:43 - RE: Vidéos sympathiques et bien faites
DAV4WS
Mineur de corde
01-10-2014, 22:00:04 - RE: Vidéos sympathiques et bien faites
une vidéo bien faite qui parle de 4roues mais pas comme les autres ,
ça va vous faire frissonner et rêver en même temps ,
ça me rappel des souvenirs et des gamelles avec mon long board en tôles de 2mm de 850mm de long
gooooooo=
[Vidéo: http://www.youtube.com/watch?feature=pla...wFek4V5aP4]
M4vrick
Mazda RX7 FD3S
01-10-2014, 22:23:11 - RE: Vidéos sympathiques et bien faites
Ce mec est fou !
Et la boite qu'il prend... ouch !*
Mais la vidéo est superbe
tonyjee
Papa pressé ....
Sujets : 115
01-10-2014, 23:33:35 - RE: Vidéos sympathiques et bien faites
(01-10-2014, 22:00:04)DAV4WS a écrit : une vidéo bien faite qui parle de 4roues mais pas comme les autres ,
gooooooo=
ça c'est ouf et je suis fan ... dans la video on voit bien la grande vitesse que prend le mec ... surtout qu'il est en version debout .. car l'évolution du long board c'est le skate de descente ou tu es couché sur le dos vers l'arrière ... testé c'est flippant
Et tu a une vitesse maxi en fonction de ton serrage de truck sur ta planche ou tes rollers ... le problème c'est que tu le découvre quand tu va trop vite et c'est souvent trop tard .... Testé accroché jusqu'à 80 km/h à une caisse en Roller ... c'étais la limite .. après ça vacille ....
Merci Daws .. c'est un festival de bonnes vidéos pour moi en tout cas aujourd'hui
(Modification du message : 01-10-2014, 23:33:58 par tonyjee.)
DAV4WS
Mineur de corde
02-10-2014, 09:30:38 - RE: Vidéos sympathiques et bien faites
un plaisir de partager mes passions... toujours aimé les sports extremes en tout genres
MacArony
Drifteur de baleine/ ponceur de mur.
Yakuza Mobile Rincée
57 - Moselle France Messages : 1 017
02-10-2014, 13:02:26 - RE: Vidéos sympathiques et bien faites
Ouutch la chute. J'en reviens pas l'effet de vitesse a mon avis vu sur combien de mettre il a volé il devait être a plus de 70kmh c'est sur
J'aime le staff JPC, les modérateurs sont mes amis
PUISSIEZ VOUS ÊTRE TOUCHE PAR SON APPENDICE NOUILLU.
LS400 1UZ-FZEB
02-10-2014, 13:06:21 - RE: Vidéos sympathiques et bien faites
tonyjee
Papa pressé ....
Sujets : 115
02-10-2014, 13:23:13 - RE: Vidéos sympathiques et bien faites
me cachait pas ... je faisais aussi le troca et la rampe ... à l'époque on essayait avec mes potes de péter les records de Taïg Khris ! ... on ridait avec lui parfois ... le dernier record que l'on a eu n'a jamais été battu de puis 1985 ... mais bon il nous a valu un accident avec un touriste Jap et 1 semaine d'hopital pour mon pote (1mois pour le touriste ) .... Après ça ... Roller interdit au Troca c'est pas nous m'sieur
(Modification du message : 02-10-2014, 13:23:57 par tonyjee.)
