DAV4WS
Mineur de corde
11-08-2014, 10:26:56 - RE: [mazda mx5] turbo! pose radia moteur/huile
un ami a qui j'ai fait une ligne complète pour turbo a voulu lui aussi garder les jeux de fonctionnement bas moteur d'origine ( donc fait pour atmo) il a serré , je ne te le souhaite pas....
mais je tenais a t'en informer par passion
Viking50
Abarth 500/Mx5
- France Messages : 562
11-08-2014, 10:56:40 - RE: [mazda mx5] turbo! pose radia moteur/huile
Il y autant de risque avec un kit Flyin miata prévu pour ?
My cars : Abarth 5OO My ex cars : FK3..FN2 CE Edition..ED9..MX5
(Modification du message : 11-08-2014, 10:57:09 par Viking50.)
DAV4WS
Mineur de corde
11-08-2014, 11:00:22 - RE: [mazda mx5] turbo! pose radia moteur/huile
tu as des détail de ce kit ? je ne connais pas en quoi il consiste ...
si c'est juste le kit turbo où autre....?
(Modification du message : 11-08-2014, 11:01:14 par DAV4WS.)
Viking50
Abarth 500/Mx5
11-08-2014, 13:14:42 - RE: [mazda mx5] turbo! pose radia moteur/huile
The FM II is a legend in the Miata performance world, and this is the latest and most powerful version. Expect approximately 230 hp at the rear wheels at 12 psi, compared to a stock 93 hp. Driveability is excellent and there`s no need to even remove the valve cover. Expect years of reliable high performance with this system. More power is available on built engines.
All of our turbo kits use the same basic hardware for super easy upgrade-ability. Full details and specifications may be found on our turbo page. Every part has been designed taking performance, durability and installation ease into consideration. We don`t believe there is a better (or more complete) turbo system available. With our kits, you won`t be making extra trips to the hardware store for nuts and bolts; every part you need is included.
Fuel management is handled by the powerful Hydra Nemesis. This gives you full control over every parameter of your engine, right down to individual injectors. A laptop is required for programming, although every Hydra is pre-programmed before it leaves Flyin` Miata. 700cc Deatschwerks injectors are included along with an integrated wideband O2 sensor, knock sensor and air intake temperature sensor. Since the fuel pressure is not changed, a fuel pump upgrade is not necessary.
The standard turbocharger is the GT2560R. This is our favorite all-around turbo, providing good power potential with good spoolup. While a larger GT3071R is available, we don`t recommend it for use on the 1.6 engine. A smaller GT2554R is also available for those who make response their highest priority
http://www.flyinmiata.com/index.php?dept...LK%20GAUGE
C'est bien celui la ? Kharnos ?
(Modification du message : 11-08-2014, 13:15:31 par Viking50.)
DAV4WS
Mineur de corde
11-08-2014, 16:37:05 - RE: [mazda mx5] turbo! pose radia moteur/huile
comparez la RTA les jeux piston chemise des atmo et turbos vous aurez votre réponse
je ne les ai pas merci de confirmer ...
Kharnos!
mazda mx5 turbo
50 - Manche France Messages : 83
11-08-2014, 19:09:22 - RE: [mazda mx5] turbo! pose radia moteur/huile
Ouai c'est bien ce kit viking. Collecteur échappement fonte FM, Gt2560r, gros intercooler en option, injecteurs 700cc, gestion hydra nemesis 2.7, dump valve turbosmart en recirculation, boost controller mecanique turbosmart, down pipe 2.5", sonde o2 large bande, ça cest le kit FM
-et ma config actuel : ligne home made 2.5" et échappement mx5 parts 2.5", radiateur moteur 42mm ilmotorsport, radiateur huile 1o rangées ilmotorsport, ventilo gros volume, mano temp d'huile prosport, combiné tein super street, kit gros frein wilwood 4 pistons, silent bloc AV/AR haut/bas ilmotorsport (pas fini de monté) embrayage exedy stage2 (arrive mercredi-jeudi) voilà de toute façon elle tournera cette année avec interne stock j'ai déjà changé le moteur car segment, coussinets vilo, aac mort ... :/ merci du conseil quand même j'en prendrais compte si le moteur ne tiens pas
cherub
mazda mx5 mazdaspeed
Liège Belgium Messages : 572
11-08-2014, 19:25:32 - RE: [mazda mx5] turbo! pose radia moteur/huile
pour l'instant je suis a 0.7b et mes injecteurs saturent si je pousse trop.
j'espere pouvoir les changer cette semaine et refaire la mapping.
mon turbo est un IHI RHF5 VJ35.
et avec 0.7b de pression et les injecteurs qui saturent quand on passe les 5000tr/min en 5e et 6e
je sort 234cv.
j'ai hate de voir le résultat avec les nouveaux injecteurs et 0.8b
Kharnos!
mazda mx5 turbo
11-08-2014, 21:22:57 - RE: [mazda mx5] turbo! pose radia moteur/huile
à moi
Kharnos!
mazda mx5 turbo
12-08-2014, 11:10:06 - RE: [mazda mx5] turbo! pose radia moteur/huile
On échange des infos donc il faut bien qu'il parle de sa caisse pour comparé les situations
DAV4WS
Mineur de corde
12-08-2014, 11:27:46 - RE: [mazda mx5] turbo! pose radia moteur/huile
je l'ai eu en MP apparemment il connais pas ces internes et le travail fait dessus
vroomdams
Man Made By Ikéa
BB9 + TA60
13-08-2014, 22:35:27 - RE: [mazda mx5] turbo! pose radia moteur/huile
Pauvre boite
TA60 & BB9
Kharnos!
mazda mx5 turbo
13-08-2014, 23:41:28 - RE: [mazda mx5] turbo! pose radia moteur/huile
nan exedy stage 2 ^^
vroomdams
Man Made By Ikéa
BB9 + TA60
14-08-2014, 21:24:29 - RE: [mazda mx5] turbo! pose radia moteur/huile
C'est costaud les embrayages comme ça pour des boites stock...
J'ai vu un paquet de boite péter à cause d'embrayages trop durs pour la boite ( et des ponts aussi )
C'est toujours mieux un embrayage qui cire un peu qu'une boite qui prendre tout dans la gueule
TA60 & BB9
